adampbowley
Mar 24, 2021Aspirant
Nighthawk MS60 Satellite intermittent connection (Blue/Red light)
I'm running 2 satellites - 1 in the house and 1 in my garden lodge.
When I installed this system, it connected well and all was good. At some point this stoppped being the case, and despite moving the sats around and establishing a connection, it isn't stable.
The distance between sats is under 100 feet and i've made sure they are running the same firmware.
If the system would have never connected in the first instance, due to being too far apart - I would have returned the system and tried something else. Annoyingly, it worked for a period of time but now it doesn't.
Frustratingly, I can get it to connect by moving things, but within minsutes it will go again. I was under the impression that once they connect to each other, if you don't make changes then it should be a consistent connection?
I'm now stuck with an expensive system that I didn't need to solve for connection in the house.
Any ideas would be very welcomed.
- adampbowleyAspirant
1 other point is that the Network Map changes alot. 1 minute it's connected to the router, the next to the other satellite...
- Christian_RNETGEAR Employee Retired
Hello adampbowley,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Unfortunately, I bought this in September. As I said it seemed to work for a while, but now can't get a consistent connection.
Just want to know if it's the distance or how if I can get it to connect 1 minute, is there a way to make it stay connected.
