Farscaper's avatar
Farscaper
Nighthawk Rax35v2 Port forwarding
Hello,
Weird issue with New router. Router has been updated to the latest firmware 1.0.11.112 before first use.
So the issue is the router won't accept more than one port and more than one port range. For example I add Tcp 3074, 2000-21999 and I tick the "use the same port range for internal port" after I apply the settings it shows me only Tcp port 3074 listed as the applied port and the port range I added is not there. I've tried imputing the required ports I need in different variations but the end result is the same where only one port is shown.
I appreciate any help.
  • michaelkenward's avatar
    michaelkenward
    Where are you doing this?
    What is it that you are trying to set up?
    • Farscaper's avatar
      Farscaper
      I'm doing this under the port forwarding section. And I'm trying to forward ports for a video game.
      • FURRYe38's avatar
        Did you first disable uPnP on the router before configuring PF rules?
