Harley55's avatar
Nov 28, 2021
Rax 120-100NAS Reboot Problem
I have a RAX120-100NAS running firmware 1.2.3.28. I noticed it reboots servel times a day. What's astable firmware to use or does anyone have a solution.
  • I checked the reviews of Netgear routes 120, 200, 500 and they all have a rebooting problem. Thanks for your help
  • FURRYe38's avatar
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • Harley55's avatar
      Harley55
      Guide
      Spectrum EU2251 Firmware 2.76.2
      Channels are set to Auto
      Near by Spectrum nothing close by
      Reset was done. Rebooted after setup.
      • FURRYe38's avatar
        Does the router reboot if the WAN cable is not connected to the modem?
        Might try downgrading FW to v24 and see if this continues or not. IF so, I would presume the router is faulty.
  • Solved
      • derekcannady's avatar
        derekcannady
        Guide
        I am also having the same issues, and have already had Netgear replace the router once.  The replacement does the same thing.  The router reboots  frequently soemtimes every 30 mionutes. I have noticed that the router reboots under heavy system load of +50% on the processor.  The only way I have been able to  lessen the issue is by turning off 2.4 Ghz WMM  services.  Unfortunately my 2.4 Ghz devices pay the price for that with slower  throughput. I can't even view some security camera streams any longer because the bandwidth is so poor. I am within the time period to return the router.  I'm hesitatnt to purchase the RAX200 because of the same issue.  I may have to try another brand after 10 years of using NG.
