Jim1590
Feb 08, 2022Star
RAX120-100N Reboots
Purchased a Nighthawk RAX120-100N yesterday at Best Buy. It is randomly rebooting. My XR500 in same location did not have this issue. I am plugged into a APC UPS system.
It has rebooted 3 times in past 30 minutes. I have not made any changes to config other than network SSID and password.
Any thoughts?
If that doesn't help, I'd exchange it at where you got it.
Maybe you got a sketchy one or one with a bad power supply. It'd be faster to exchange than go through support/rma.
What firmware version are you on?
Have you tried reinstalling the firmware, then doing a factory reset/reinstall? Maybe something was corrupt in the firmwareI will do that tonight after work. Hoping to have a "to-do" list from here of steps to take.
