Freebird317
Feb 14, 2020Luminary
RAX120 Open Ports On Internet
Does the RAX120 have a firewall? I scanned my ip and found lots of open ports. IP is scrubbed.
Discovered open port 21/tcp on 4.4.4.4
Discovered open port 80/tcp on 4.4.4.4
Discovered open port 110/tcp on 4.4.4.4
Discovered open port 143/tcp on 4.4.4.4
Discovered open port 25/tcp on 4.4.4.4
Discovered open port 8080/tcp on 4.4.4.4
Discovered open port 8008/tcp on 4.4.4.4
Discovered open port 5060/tcp on 4.4.4.4
Discovered open port 8001/tcp on 4.4.4.4
Discovered open port 2000/tcp on 4.4.4.4
Completed SYN Stealth Scan at 08:05, 4.47s elapsed
- KillhippieProdigy
using shields up I have total stealth on the fiurst 1000 ports, have you factory reset your router at after any updates? What did you use to check ports?
- KillhippieProdigy
is this an app on your computer scanning within your network? In which case it seems to be opening ports to connect to scan me most odd and id would remove it. Try shields up as that scans from outside the firewall, not from within.
- Freebird317Luminary
I am using nmap scanning my IP from work
- KillhippieProdigy
I think you are hiitting your ISP first thats why see this post;
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Open-Ports-WAN-side-on-R7000-Router/td-p/1203861
Try scannng your IP from home using shileds up, I tried scanning my IP and the first1000 ports on the RAX120 are true stealthed
