Moshel's avatar
Moshel
RAX120 rejects WiFi connection and responds Wrong password message
Hello
I just connected my new WiFi router RAX120 Firmware V1.0.1.108 using laptop with win10. I have succeeded connecting several WiFi devices (PC, Android tablet, Android phone, IPhone etc.). I fail to connect WiFi TV box. I get "wrong password". I cannot connect it even using WPS.
This TV box was WiFi connected to my previous WiFi router and worked fine. Please help.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Moshel,
    You may need to reset the TV if that's and option.
    Christian
    • Moshel's avatar
      Moshel
      Thank you Christian
      The TV box is an android external to the TV (connected by HDMI cable). I have rebooted it several times and even turned it off and on. Nothing helped. Only turning off the security (no password) helped. The same TV box was connected to my previous router with password and worked fine.
  • I have the same problem.
    I fail to connect TV by RAX120. but the TV can connect to old router.
    • michaelkenward's avatar
      michaelkenward
      How about the TV reset suggested by Christian_R?
      Connecting a TV to a network usually starts with the TV and its configuration process.
      Hard to say more without knowing what the TV is and how you are trying to connect it. Wired or wifi.
  • Purchased rax120 about 3 weeks ago. Had the same problem when trying to connect older devices on 2.4ghz band. Changed auto channel setting in rax120 to a hardcoded channel (in my case 6) and problem went away. Everything has been running smoothly and fast since.
    • Moshel's avatar
      Moshel
      Hi Steih
      Thank you. Your solution did not work for me (fix channel). On the other hand without password security it works fine in my case. I have found another solution: Setup my old router as a bridge and connected it to the TV box (wired to the bridge - old router).
