rax120_rax80's avatar
rax120_rax80
Apprentice
Mar 09, 2020
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/ 1Gbps service from my ISP, the modem links a RAX120 router via a single 3' CAT6 (i know, overkill), and I have a single 100' CAT5E connecting the RAX120 to a RAX80 in AP mode on the other side of my property. I have a dynamic IP address provided to my modem from my ISP, the modem provides a single address to the RAX120 WAN connection via DHCP, DHCP is configured on the RAX120 to provide a separate NAT for all clients, and the RAX80 has a static IP address set within that NAT subnet. When the problem began today the RAX120 was running FW 1.0.1.114 and the RAX80 is running V1.0.1.70_1.0.30. Nothing in my environment has changed for a month and this issue arose out of nowhere.
Anyway, this morning I noticed that none of my TV streaming devices were able to connect to their streaming services. The streaming device in one side of the house is connected via WiFi (802.11ac) and the device on the other side is connected directly to the RAX80. I found that I was unable to ping any web sites (www.google.com) from my laptop when connected via 5Ghz or 2.4GHz on the router or AP, but I was able to ping the IP addresses for these sites (172.217.0.36). I could ping DNS server IP addresses for my ISP and other public DNS server addresses, yet I couldn't query DNS running on the RAX120 to get a non-authoritative response. However, I did get an authoritative response when I ran an nslookup and specified an external DNS server. After logging into the RAX120 I could see that it was pulling the DNS server IP addresses from my modem as expected, which were some of the same that I was able to ping without issue. I checked the logs and nothing abnormal popped up. Just the standard logins of MAC addresses and some BS DoS from known services. So after kicking the RAX120, everything began functioning again and I was able to query the router get DNS answers.
Issue solved with a simple kick of the router right? Wrong… 20 minutes later the issue reoccurred. This time I took it a step further and sequentially powered down and up the hardware. Modem, router, and AP. Again, the issue was resolved for a short time, but then randomly came back. I dug into the RAX80 logs to see if it was causing the pain and saw the following.
[Time synchronized with NTP server] Sunday, Mar 08,2020 19:50:31
[Internet connected] IP address: X.X.X.X, Sunday, Mar 08,2020 19:50:20
[Initialized, firmware version: V1.0.1.70_1.0.30] Sunday, Mar 08,2020 19:50:20
[Time synchronized with NTP server] Sunday, Mar 08,2020 19:47:26
[Internet connected] IP address: X.X.X.X, Sunday, Mar 08,2020 19:45:57
[Initialized, firmware version: V1.0.1.70_1.0.30] Sunday, Mar 08,2020 19:45:57
[Time synchronized with NTP server] Sunday, Mar 08,2020 18:54:28
[Internet connected] IP address: X.X.X.X, Sunday, Mar 08,2020 18:54:08
[Initialized, firmware version: V1.0.1.70_1.0.30] Sunday, Mar 08,2020 18:54:08
[Time synchronized with NTP server] Sunday, Mar 08,2020 14:27:44
[Internet connected] IP address: X.X.X.X, Sunday, Mar 08,2020 14:27:04
[Initialized, firmware version: V1.0.1.70_1.0.30] Sunday, Mar 08,2020 14:27:04
The FW reinitializing without me intervening with a reboot is a bad sign, so I isolated it out for a factory reset and rebuild. As an aside, the RAX80 has been problematic in the past with it basically corrupting it’s ARP table and not forwarding L2 traffic, so I thought it definitely could be horked once again. Nevertheless, after a rebuild and a few hours later the problem resurfaced.
The next troubleshooting step I took was to upgrade the RAX120 FW to the latest security patch 1.0.1.118, which still didn’t resolve the issue permanently. Now I’ve downgraded the firmware back to 1.0.1.108, and stepped back to .114 and .118 hoping it won’t resurface. It’s been about an hour, so my fingers are crossed. I don’t want to go down the path of a factory reset of the RAX120, cuz it’s a major PITA to redo all my settings with ACLs and port forwarding. I could just restore from the backed-up firmware after a reset though, which is the next step I’ll take if this crops up again.
Thoughts? Let me know if you guys have seen oddities like this and if Netgear is doing anything to actually solve customer problems. I liked the RAX120 cuz I have a system connected via the 5GbE port and NAS via LACP and the performance is great. But this is only one of many problems that I’ve had with these devices and I’m on the verge of giving Netgear the finger to go with a 10GbE switch and some Ubiquiti APs… and thrown psfense back in while I’m at it.
