Loronew
Oct 20, 2020Aspirant
RAX120
My RAX120 drops my fire sticks but maintains a connection to my iPhone, iPad and other 20 devices. If I do a factory reset everything works again but about 2 weeks later the same thing occurs. Can anyone help?
- Christian_RNETGEAR Employee Retired
Hello Loronew,
Have you had a moment to get in contact with Amazon's Fire Stick support team regarding your Fire Stick issues?
Christian
- LoronewAspirantNo. I figured since the problem is temporarily resolved after doing a hard reset of the router that it was a software issue with the Netgear Router. I have 5 fire sticks that all stop working at the same time until I reset the router then they work perfectly again
Lorenew,
You may also check to see if your device is due for a firmware update.
Christian
