microsvc2
Jan 30, 2021Tutor
RAX20 / AX1800 Firmware readySHARE bug?
I have upgraded the firmware on my RAX20 to V1.0.2.82_2.0.52 and it is working EXCEPT that the readySHARE USB LED is not on on ther front of the router. I can access readySHARE as before but the LED is not lit. The LED setting is for all LEDs to be on.
Is this a BUG in the firmware or something else?
Thanks!
Bob
BTW: My Router RAX20/AX1800 is not in the Model list above.
- Christian_RNETGEAR Employee Retired
Hello microsvc2,
May you factory reset your router and let us know if your issue persists.
Christian
- I assume I will lose all my changes, is it OK to export my config and import it after reset?
Hi microsvc2,
Yes, you may do that.
Christian
Is there any Netgear techs out there that can verify this and get it fixed?
Hi microsvc2,
I'd like for our support team to reach out for further investigation. May you send me a private info with your email, phone, and serial number.
Thanks,
Christian
- Retired_Member
Hi microsvc2,
I recently purchased the Netgear RAX20 router, and faced the same issue as yours after upgrading the firmware to V1.0.2.82_2.0.52. I wanted to know if your issue has been resolved and if yes, then how?
Thankyou.
No, this is not resolved. I spoke directly with an engineer in Tiawan (I think) and he said this should be fixed in the next firmware release. I just went back to my previous release for now and am watching for a release higher than 82. It's been months already. Apparently not a priority.
