tripletaco's avatar
tripletaco
RAX20 I can no longer change transmit power level
I can no longer change transmit power level on RAX20.  I don't want to transmit on higher levels.  I want 25%.  Update in firmware must have changed this.  I bought the router because I wanted to lower transmit power levels for better healthy environment.  This needs to be fixed.
  • michaelkenward's avatar
    michaelkenward
    Was this ever possible for that router?
    If so, find the firmware that supported this and install that.
    You then run various other risks – on security for example – but at least they won't fry your brain.
    • tripletaco's avatar
      tripletaco
      How do I find the last update that still allowed power level management?  Downloading and trying each of the latter firmware versions until I find the most recent that doesn't break the power level management would be extensively time-consuming.  Maybe someone on the Netgear team knows the answer.
      Paul
  • Any time you feel a firmware update has caused problems, the first course of action is to perform a firmware default reset and reconfigure from scratch.  Do not import a previously saved configuration file.  That action will often reinstate whatever issue you are trying to correct.
    Have you performed a firmware default reset on your router since the firmware was updated?
      tripletaco
      Kitsap,
      I used to live in Kitsap County.  Bremerton to be precise.  I bet you are familiar with the place.  Cool name!
      Paul
  • I'm still wanting to change the power level on my RAX20.  Maybe someone new will see this.  I was hoping for a list of firmwares for the RAX20 that shows changes on each version.
  • FURRYe38's avatar
    NG seems to not support power level adjustments on there routers anymore. If NG hasn't change this by now then mostly likely NG won't.
