bdonhbam
Mar 24, 2020Guide
Rax200 firmware update V1.0.2.8_1.0.45 causes the router to go offline every few hours
I just updated my Rax200 router with the firmware update V.1.0.2.8_1.0.45 this morning. It has lost connection to the internet 4 times so far today. The Netgear CM1100 connected by an Ethernet cable seems to remain on line and connected to Comcast. But the router indicates it is not connected to the internet via a wired connection, I believe it did not allow me to connect wirelessly with a new connection when this occured. The Nighthawk IPHONE app would not connect to the router either, Powering down the router and waiting corrected the problem, as well doing a reset via Routerlogin via a wired connection fixes the problem. I suspect there is something unstable in the firmware that looses connection with the cable modem and wireless devices. This expensive a Router should not have problems like this crop up. I have checked for new firmware in the routerlogin connection but none has shown up yet, 6:30 PM PST 3/24/20.
Regards
Bruce Donham
- psychopomp123Luminary
Same issue here. Upgraded to the latest firmware yesterday and the router has already disconnected twice during the night.
Going back to my rock solid Linksys EA9500v2 until Netgear sort out the bugs on the RAX200.
- bdonhbamGuide
I am considering rolling back to the prior Firmware version till this is fixed, too many times I get a complaint the Internet is down impacting their streaming, which is sudenly is more important in these days of stay at home orders...
Brice
I'll give my RAX200 another chance. Done a hard factory reset and manually re-configured all settings from scratch. Hopefully it will behave itself now....
- RajaDajaLuminarySo, like a lot of us did.......we reverted back to the previous F/W. Have you tried? Go to Netgear support download and get it. For some such as myself no issues. Good luck
- RajaDajaLuminaryForgot to mention, recommended to factory reset after installing previous version of F/W
Also uncheck auto update in the update firmware section.1.0.2.88 Firmware does not fix the issue. Both Wifi bands completely drop and dissappear for a few minutes. Can anyone recommend another brand that works well for them? My R7000 works better than the RAX200 but I have a lot of devices so I was looking for a better router. The RAX200 is not.
- Retired_MemberLatest firmware causes router to revert to factory defaults anytime it is rebooted. Also, if you try to restore from a backup file it reverts to factory defaults. Please help!
