Ufm-uk
Dec 26, 2022Aspirant
Rax200 wrong password
Recently my rax200 seems to be kickijg Everything off and preventing access via Wi-Fi with a “incorrect password” message. When the password has not been changed.
- KitsapMaster
Ufm-uk wrote:
Recently my rax200 seems to be kickijg Everything off and preventing access via Wi-Fi with a “incorrect password” message. When the password has not been changed.Additional information would be very helpful.
What is the brand name and model number of the upstream modem/gateway/ONT (optical network terminal)?
Are you sure the Ethernet cable between the RAX200 and the upstream device is good? Cat 6 cable is recommended.
How long has it been since you powered down (pulled the power cord) and let the router set for a couple of minutes before restarting?
What is version number of the firmware installed on your RAX200? The "latest" is not an answer. A version number is required to confirm your answer.
- Ufm-ukAspirant>>> Are you sure the Ethernet cable between the RAX200 and the upstream device is good? Cat 6 cable is recommended.
Yes that’s all good
Firmware Version
V1.0.10.140_1.0.79- KitsapMaster
Yes that’s all good
Firmware Version
V1.0.10.140_1.0.79Repeat questions from a previous post. Ignoring them will not make them go away....
