ShyHigh420's avatar
ShyHigh420
RAX35
Got a dos attack on this router had to manually block the services port 67 and not 443 since that is dhcp and IP. So if anybody has any issues I suggest you check your logs and see if you have any ip that is not local for example this ip is a local (192.168.1.2) and this ip (90.120.102.253) using something like a dos ack scan or something similar as that is someone actually attempting to hack you remotely and is not local. It sped up my internet the second I did all of this. One of my neighbors thought it would be cool to de auth Packets and kick me off my network then they tried to dos me so trust me when I say this works flawlessly.
  • michaelkenward's avatar
    michaelkenward
    ShyHigh420 wrote:
    Got a dos attack on this router ....
    Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
    Search - NETGEAR Communities – DoS attacks
    Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
    Here is a useful tool for that task:
    IPNetInfo: Retrieve IP Address Information from WHOIS servers
    • ShyHigh420's avatar
      ShyHigh420
      ok so I went with your option and did a whois and is was my isp abusing a port and sending dos attack: fraggle attacks so I ended up copying the logs to send to comcast on this website https://internetsecurity.xfinity.com/help/report-abuse they mitigated the issue now thanks for your help much appreciated
        michaelkenward
        Interesting.
        Another interpretation would be that those reports are artefacts created by Netgear's logging system, which is known to be problematic.
  • Hello.
    How do I stop logging of these Fraggle attacks?
    Can I put a specific IP Address on a blacklist on the router? (Tried to today in Advanced/Security/Block Services for User Defined/UDP/67/67/Only this address 96.120.100.241 and get error "Invalid user defined service type.")
    My router is actually a RAX54S-100NAS. Same problem with DoS Fraggle showing up in logs.
    [admin login] from source 192.168.1.8, Saturday, Mar 02, 2024 15:17:51
    [DoS attack: Fraggle Attack] from source 96.120.100.241,port 67 Saturday, Mar 02, 2024 15:12:27
    [DoS attack: Fraggle Attack] from source 96.120.100.241,port 67 Saturday, Mar 02, 2024 15:02:25
    [DoS attack: Fraggle Attack] from source 96.120.100.241,port 67 Saturday, Mar 02, 2024 14:52:12
    [DoS attack: Fraggle Attack] from source 96.120.100.241,port 67 Saturday, Mar 02, 2024 14:41:19
    My ISP is Comcast/Xfinity, 96.120.100.241 is a Comcast-owned IP address geographically close to me.
    I spent >4 hours back and forth in chats and on the phone with Xfinity Inet Security Team folks yesterday trying to sort this. They finally told me to buy a newer "gamer router" to solve the problem. I did wonder yesterday if this logging behavior was a Netgear firmware "feature", and on further research today, that would seem to be probable cause in this case.
    I'm disappointed to find this is a years long ongoing issue with Netgear firmware never resolved.
    • microchip8's avatar
      microchip8
      Master
      As mentioned, these are most likely false positives and harmless. Block Services is only for local IPs, not public ones you get from ISP. Disable DoS protection, you're not missing anything. If you don't want to, disable loging of DoS
      • Muddy_Street's avatar
        Muddy_Street
        Yes will do - thanks very much. While messing around, I have not seen the way to stop logging specific events, and not much in the USM pointing the way. New to NG products. If you have specific knowledge of the procedure, please share.
        [EDIT 13:06 - logged in, found the check boxes for items to log or not on /Advanced/Administration/Logs, scroll down]
        BTW, just finished reading through
        Trying to understand nature of "DoS attack: RST Sc...
        Great conversation, thanks for the time involved.
