SomeGuy_S
Sep 01, 2023Aspirant
RAX38v2 cables not connected
I have a Nighthawk AX4 RAX38v2. It worked fine, but I had to turn it off for two weeks and when I turned it back on, it stopped working. The internet access LED does not light up. After rebooting, the app reports that no cables are connected. If I plug the cable directly into the PC, it works fine.
I'm trying to set up a WI-FI router using the netgear app (android). I've tried several versions of frameware, including the newest, but it never works.
I called my ISP and they couldn't do anything. I tried setting it up through the app and from the PC, but only changed the SSID. This has not helped. Please help me sooner rather than later.
Something at your location with your ISPs ONT isn't working with the RAX router. Something to check with the ISP about.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router- SomeGuy_SAspirant
I just tried resetting and rebooting in the sequence you wrote - didn't help. I also changed the DHCP, but that didn't help either.
I don't know the Mfr and model# of the modem/ONT of the ISP that the NG router is connected to. But I can call my ISP tomorrow when they start working again if that could be the cause.
There is a CAT5 LAN cable connected to the NG.- FURRYe38Guru - Experienced User
CAT5 is only rated for 100Mpbs. CAT6 is recommended.
