R-M-H
Jun 29, 2020Aspirant
RAX40 — Nighthawk AX4 4-Stream WiFi Router
After the latest firmware update, my router sporadically stops broadcasting networks. I have called tech support several times and have gotten nowhere. No issues on the carrier line and I have factory defaulted the router but still the issue continues. Anyone else having trouble?
- Christian_RNETGEAR Employee Retired
Hi R-M-H,
May you send me a private message with your case number(s) and contact info and I can see if I can get your case escalated.
Thanks,Christian
- Erwin_JongAspirant
Any news on this topic. I flashed the latest firmware on this AP right after purchasing but no client is seeing the SSID while it is not hidden.
Can i otherwise flash an older firmware again to see if that works better ?
- R-M-HAspirantHas this been resolved? I’m hesitant to upgrade firmware.
- itsmehueyLuminary
R-M-H wrote:
Has this been resolved? I’m hesitant to upgrade firmware.no it has not. Beta firmware is still in works and being tested. I'm currently using the beta firmware and it's been good for the most part. Awaiting response back from L2 support rep working on my case regarding further tweaks required to the firmware as I did encounter an initial WIFI drop and issues logging into the router admin/debug console..
