Aljesh's avatar
Aljesh
rax43 No connection to telstra modem after firmware update
Nighthawk AX5 AX4200 5-Streem Wifi Router
Recent update of Firmware Caused the router to not pick up internet connection from modem.
internet light is red.
New network cable.
  • What modem/gateway is it?
    What firmware version did you install?
    did you try a factory reset and reinstall? Anytime there's issues after a firmware change, its a reasonable option.
    • Aljesh's avatar
      Aljesh
      AX4200 WiFi Router (RAX43)
      Nighthawk® 5-Stream Dual-Band WiFi 6 Router
      Using a new Telstra Smart modem gen 2.
    • Aljesh's avatar
      Aljesh
      Same Issue With A Ñew Version Of The Firmware.
      Modem Is A Smart Modem Gen2 Lh100 Red Box (arc)
      This is A New Unit.
      No Internet Connection Still.
      • plemans's avatar
        Guru
        That modem has its own integrated router functions. It does cause a double nat.
        options (only use 1)?
        1. put the LH1000 in modem only/passthrough mode.
        2. put the netgears IP address into the LH1000's DMZ
        3. put the netgear in access point mode.
