rpmurph8300's avatar
rpmurph8300
Apprentice
Jul 20, 2020
RAX50 Latest Firmware Not Available On Web/GUI Update Doesnt't Work
For some reason RAX50 doesnt show up in the model list for this post.
RAX50 GUI shows latest firmware is 1.0.2.32. Whats on the Netgear site is 1.0.2.30 (Hot Fix) and it says beta in the title which seems sketchy. Where is the 1.0.2.32 firmware download on the Netgear's site?
Also when you try updating the firmware from the GUI you get a LANGAUGE failure. Hopefully this gets resolved soon. Thanks.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello rpmurph8300,
    Thanks for your feedback, I'll have it forwarded to the necessary teams. Firmware v1.0.2.32 should be up on the support site soon.
    Christian
    • rpmurph8300's avatar
      rpmurph8300
      Apprentice
      Is there an ETA when it should be uploaded to the Netgear site? Thank you.
        rpmurph8300
        Apprentice
        The firmware is available on the site as of this morning. One issue i found though is on the Guest Network settings you are unable to remove the check box for "allow guests to see each other and access my local network." I dont know about anyone else but if I'm enabling a guest network i dont want them having access to my local network, just the internet. I've attached a picture for reference. Thank you.
      rpmurph8300
      Apprentice
      Hi Christian,
      Looks like the same issue with the latest firmware. Can you assit with get this resolved? There's a GUI Langauge error that appears when trying to update from the GUI so it has to be uploaded manually. Thank you.
        Christian_R
        Hi rpmurph8300,
        Thanks for bringing this up. I'll have it forwarded to the team.
        Christian
