Johncorsaro's avatar
Johncorsaro
RAX70. Changing to 10.0.0.1
Router set to 10.0.0.1. Went into advanced settings and checked off router mode several times and saved config. Rebooted and still 10.0.0.1. Had no choice but to hit the reset and start over…. This day 2 of installing the router.
  • plemans's avatar
    Why not just use access point mode if you're wanting dhcp disabled?
    • Johncorsaro's avatar
      Johncorsaro
      I never wanted to disable dhcp nor pass thru or as bridge. The router decided to do it automatically . Which should never happen unless done so thru advanced settings.
  • michaelkenward's avatar
    michaelkenward
    A sign that the RAX70 is behind another router and the setup process is trying to avoid  problems.
    What is Double NAT? | Answer | NETGEAR Support
    and
    How to fix issues with Double NAT | Answer | NETGEAR Support
    Or just go for AP mode as plemans advises:
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    Or explain exactly what you are trying to achieve with this juggling trick.
      Johncorsaro
      Not running behind another router. Is connected directly to cable modem that has no router capabilities. Please update firmware so these modes can only be achieved if the end user chooses that mode…thru the UI menu
      • plemans's avatar
        1. we're not netgear.
        2. if you're disabling dhcp and don't have another router connected, of course you're going to have issues. A modem only device needs a router connected thats handling dhcp/nat. If you're disabling that, what result do you think you'll get?
