Retired_Member
Feb 03, 2019RAX80 USB Printer not detected
I have a problem.
After connecting different printers to the router using a USB cable. No printer is visible on my computer .My printer in not visible in my panel control printers.
Any idea?
Mac Os 10.14.3
firmware 1.0.1.40
- DarrenMSr. NETGEAR Moderator
You may want to check out this Kb and get the usb control center
https://www.netgear.com/support/product/ReadySHARE_USB_Printer.aspx
DarrenM
- Retired_MemberUnfortunately this software doesn’t work with newest Mac OS X 10.14
- Retired_Member
