theMPG
Dec 13, 2021Tutor
Replacing BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200, step by step
Replacing my BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200, step by step guide if possible. Hi. Looking for some not-too-techie guidance and help, if possible....
- Dec 13, 2021
Thanks so much. Quite often it's knowing where to get the answer to the problem, but knowing what to ask, is often the bigger issue.
I greatly appreciate the forum details, heading there now, to see what's what, or ad a post.
many thanks, 👍
Dec 13, 2021Guru - Experienced User
Turn off and unplug modem.
Turn on computers and rest of network.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
theMPG
Dec 13, 2021Tutor
many thanks, 👍
