JimmyW's avatar
JimmyW
Luminary
Feb 28, 2024
Router doesn't log me out and security question
My router is an RAX50v2 with Firmware Version V1.1.4.28_2.1.26. It seems that the Router does not log me out when I click the logout option under my user account icon in the upper left. After I click logout and the router window closes, the router window will reopen without the need for a password next time I open it. Rebooting my Win 11 system will clear everything and require a password to access the router. Is this normal? Other than restarting, is there a way to log out and be sure that my router is secure?
In my wireless setup I noticed that the router was set to use WPA2-Personal, and other options are available, as in the screenshot. Is this the most secure setting that will work with my router and Win 11 and iOS systems? Thanks.
  • JimmyW's avatar
    JimmyW
    Feb 29, 2024
    It's the Bitwarden password manager extension. Usually, if the autofill-on-page-load option is selected (mine is), the creds are entered in the login fields as asterisks and I must click OK. However, with the router login, for some reason, login is fully automatic and the router page opens without displaying the masked creds or requiring my OK. I may question the Bitwarden forum about this, although it really isn't a big deal or a security risk.
    And because the Bitwarden extension loads as Chrome starts, it gives the impression that the router login creds survived a system reboot. They really didn't.
  • FURRYe38's avatar
    Happens with different browsers?
    Be sure to clear out all browser caches before entering into the routers web page.
    I'd factory reset the router and setup from scratch.
  • >even if you don't logout, that signed-in state times-out soon, within a few minutes.
    Not on mine. It keeps me logged in indefinitely.
    >that 2nd device won't be able to hitch-hike on a the previous authentication. a screen like this intervenes, demanding a >new login.
    True. That's what the Netgear tech told me, and that was really my concern, e.g., someone war driving and getting into my system. The bottom line is that I will be logged out when I reboot my system.
    >there.  feel better?
    Yes, thanks very much!
    • JimmyW's avatar
      JimmyW
      Luminary
      Nope. Mine stays logged on. While this may not pose a security risk, it is a bug that Netgear should address.
      • JimmyW's avatar
        JimmyW
        Luminary
        I have the Nighthawk app on my android phone, but don't use it.
