Tarra85's avatar
Tarra85
Router is Blocking a Favorite Website
For some reason my router is blocking one of my favorite websites (www.appagg.com) - it’s never done this before until about a couple weeks ago. I have spoken to my cell company, modem provider and both agree it’s a router issue cause the site is not being blocked by them they say. I tried doing a chat with NetGear but my support trial is up so I would have to re-sign up and I can’t right now. They did send me a email of the steps to reset my router but it didn’t fix it. When I try to go to the website it just is a blank page that acts like it’s trying to load until it times out. If anyone knows how I can fix this I would be forever grateful. I cannot do anything that has to be done from a computer cause mine is not working so I have to be able to do the steps from my phone/ipad. Thanks in advance.
I have the Nighthawk AX4 AX3000
  • FURRYe38's avatar
    What model router do you have? RAX?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
    I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
    Press the back reset button for 15 seconds then release.
    https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
  • Hi,
    I’m unsure of how to get that info of the internet provider but it’s Spectrum. I have done a factory reset twice already to no fix and also a reboot. As for the model number of the router when I look on the sticker on the bottom of the router it says “Nighthawk AX4 AX3000”. I have attached what the Nighthawk app says under Router Info incase that would help. I can’t do anything wired to a computer cause I don’t have access to one right now. And the Netgear Armor is expired on my router so it’s not being used.
    • FURRYe38's avatar
      Should be a sticker on the ISP modem/ONT about it's model #.
  • plemans's avatar
    Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
    CloudFlare
    IPv4: 1.1.1.1 and 1.0.0.1
    IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
    GoogleDNS
    IPv4: 8.8.8.8 and 8.8.4.4
    IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844
