  • Hi, I tried the same and it appeared to work, however the result of saving the new setting did not appear to show up, until I was timed out, then logged back in as admin again.  Now showing "Not configured".
    • ronald_fr's avatar
      ronald_fr
      Luminary
      Hello,
      thanks for you response, but I don't understand : on my RAX40 I'm running 1.0.3.80 (it was same with previous release)
      "Enable Router's PIN" is unchecked. Router has been rebooted some times, web admin has timed out a lot and nothing changes :
      I always have "Wi-Fi Protected Setup Configured"
      Best regards
      Ron
      • LSIMM's avatar
        LSIMM
        Guide
        From reading other forum posts it sounds like lots of bugs in various firmware versions, including the most recent, which I'm also on.
        Who knows, hopefully they can sort out lots of these issues in the next release.
