Gianlucam's avatar
Dec 24, 2018
What is the max number of supported WiFi devices for the new Nighthawk AX12?
Hello,
I know that the new Nighthawk AX12 hasn't been released yet but I was wondering if someone here could tell me what is the number of maximum WiFi devices it can support, since it's aimed to very large homes with a high number (but not specified) number of WiFi devices.
I have a fully automated smart home and I have between 85 and 90 different WiFi devices (smart light switches, smart outlets, wireless  speakers, and other streaming devices), and I've been struggliing to find a WiFi router that supports that kind of workload. I have tried different brands of routers including the NETGEAR Nighthawk X10, but none of them is up to the task.
Thanks,
-Gianluca.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    12 Stream AX WiFi—4X Better Performance Twelve WiFi spatial streams - four in the 2.4GHz band, and eight in the 5GHz band offer four times the device capacity as compared to typical 2x2 AC WiFi. AX WiFi also supports sending up to eight multi-user MIMO transmissions at a time, up from four for AC WiFi. This results in a significantly improved network capacity and benefits the performance of all legacy devices.
    DarrenM
    • James721's avatar
      James721
      Luminary
      DarrenM
      Yeah right sounds good on paper. What real life is remains to be determined. With the broken firmware Natgear has out in the public right now on MANY of there routers not just one. I would be very surprised if this new one works as intended out of the box.
      No way at least for me i would even bother with any Ax router until proven otherwise. James !!
    • IrvSp's avatar
      IrvSp
      Master
      DarrenM, you didn't answer the question that was in the subject.
      " What is the max number of supported WiFi devices for the new Nighthawk AX12?"
      You said "This results in a significantly improved network capacity and benefits the performance of all legacy devices.". That means nothing in terms of the question.
      • myersw's avatar
        myersw
        Master
        I was thinking the same thing when I saw the response. Question is how many devices? Older Netgear were in the 32 device range as I recall. Would hope these are higher. My Unifi AP is rated at 200. I will probably never have that need.
