AmazingAbe's avatar
AmazingAbe
Which one for aggregation feature
Hello,
I need to buy a router to aggregate two internet connections (ethernet). Some friends told me that the Netgear Router WiFi Nighthawk AX12 AX6000 does that but I've read it is suggested for larger spaces that need powerful anntennas to increase the wifi ragne. Instead my office is pretty small and I was wondering if it's not better for me to buy the Nighthawk AX4 AX3000 but I don't know if it aggregates multiple connections.
Any suggestion? Even other models are fine to me. Top would be standard WIFI power and aggregation. Thanks in advance.
  • michaelkenward's avatar
    michaelkenward
    Do you mean two completely different Internet services? Different logins and external IP addresses?
    I don't think that is possible. Certainly not with consumer grade equipment.
    • AmazingAbe's avatar
      AmazingAbe
      The AX12 AX6000 does that. It's not a matter of loggin in. If you have a cable you don't need to log in because the signar arrives from the provider router and enters into the Netgear via ethernet. I just want to understand if the "smaller" version of the moden can do it.
        michaelkenward
        There is no Netgear AX12 that I can see. Do you mean RAX120?
        If so, "aggregation" there means that it connects "two Gigabit LAN ports or use Multi-Gig 5G Ethernet as WAN port (configurable)".
        The RAX80 also does "PORT AGGREGATION—Ability to aggregate two gigabit LAN ports for faster file transfers".
        Not sure that this has anything to do with combining two different Internet sources. More a case of getting more speed out of one connection.
  • I have been fighting with the AX4 for over three months.  It is not stable.  DO NOT waste your time with this device.
      michaelkenward
      You mean RAX40? That's the modem number. It is Netgear's only AX4. But it helps to be clear.
