esebm's avatar
esebm
WiFi Problem?
Hi, I have a Netgear AX1800 WiFi Router which seems to have a wifi problem.
The wifi signal on my wife's laptop one floor above the router fluctuates from all bars down to zero within a minute. It used to work fine ( 2 bars at least) for a year and suddenly it makes difficulties. What is going on here?
Thanks for any help.
  • CrimpOn's avatar
    CrimpOn
    esebm wrote:
    I just don't understand how the signal strength can vary from zero to full.
    Yes, this makes absolutely no sense.  When both a smartphone and a laptop experience the same behavior, "something is wrong".
    esebm wrote:
    Would a repeater help?
    Are any of the previous routers still available (in a box, perhaps?  I have 3-4 old routers.)
    WiFi5 (802.11ac) repeaters are widely available for under $30.  Name brand WiFi6 (802.11ax) are typically a bit more expensive, coming close to the cost of basic WiFi6 routers.
    There is one WiFi6 repeater on Amazon for $19.99 USD that gets decent reviews.  Less than a meal out for two or a "top shelf" bottle of wine.  If it doesn't help, Amazon has a decent return policy or you might find someplace else in the house that could benefit from it.
    https://www.amazon.com/Cudy-Extender-Wireless-Booster-1200Mbps/dp/B08W2V5BCN/ref=sr_1_13?crid=1OV69G09NX6VD&dib=eyJ2IjoiMSJ9.4lf9nYDHcd906UCfK4dd7Zl6fO17PRqpDesC6loQTVi56sHAVGlsplTzmC4UPdiN8v8pZjgoSizAQEztMpyV_aEtRva_GqOKlGsPxtLUHejAPYHbxQ-m_vBwCSEl2j3Ql2On6p3eJe_oEhKoH4-q177ZZYL0hXpSObErsmofwVYaI683t-vbctcGESRsfAq1_LFZFJoIMmx-hFWAv6PsKs2nJk1lMlMvoz-tmIvRaAc.efc00VvgrQi2ss74_g-gSseFFa9fdIfmO36crw3MjzY&dib_tag=se&keywords=%22wifi+6%22+extender&qid=1753055543&sprefix=wifi+6+extender%2Caps%2C222&sr=8-13#averageCustomerReviewsAnchor
  • Location: The laptop as well as the router have been in the same location for about 4 years, with various routers.
    Laptop: My wife's smart phone shows the same issue.
    The  router is about 1 year old, I'm not ready to buy a new one.
  • CrimpOn's avatar
    CrimpOn
    Thanks.  WiFi is really sensitive to obstacles in the path between WiFi access point and user device.  I was visiting in an 80 year old house and the WiFi signal would drop off to almost nothing in one room.  Turned out there was a brick chimney running up from the basement and all that brick cast a "WiFi shadow".
    That seems to leave three possibilities:
    • The location.  Perhaps trying the laptop in different places around the house to see if the problem occurs in other places.
    • The laptop.  Maybe a friend could bring another laptop over?  Tablet?  Chromebook?  Smartphone?  If a different device shows the same issue, that would argue against it being the laptop.
    • The router.  (We ALL want to blame the router.)  WiFi6 routers go for under $100 on Amazon.  (a bit more for a "mesh" system which would place one unit on each floor.)  Amazon has a great return policy.  I believe Best Buy may be gracious about returns as well (if there is one nearby.)
  • The laptop always remains stationary and there are no other wifi devices.
  • CrimpOn's avatar
    CrimpOn
    Thanks for clarifying.  Does this happen when the laptop remains stationary (not moving at all)?
    Are any other devices affected the same way?
  • RAX 10!
    The signal strength indicator in the laptop taskbar goes from Zero to all bars and back, the internet gets interrupted.
  • CrimpOn's avatar
    CrimpOn
    It is often helpful to know the actual product number from the label on the bottom of the router.
    (AX1800 is a measure of 'speed'.)
    Does this signal strength change appear on the laptop display itself or on a "WiFi app" that is being used to look at the WiFi?
