plantbasedgamer
Feb 10, 2019Tutor
Xbox One X Can't Connect to Party On Nighthawk AX8
I purchased a Nighthawk AX8 earlier in the week and everything has been fine up until today where I cannot join any parties. The moment I try to connect to a party, not only does the Xbox One X disco...
DarrenM
Feb 12, 2019Sr. NETGEAR Moderator
Have you done any port forwarding for the xbox?
DarrenM
- plantbasedgamerFeb 14, 2019TutorI don’t have port forwarding enabled.
I’ve enabled both IPv6 and UPnP and while the Xbox One X connects flawlessly, the moment I connect to a party is when it completely knocks the WiFi out.- DarrenMFeb 15, 2019Sr. NETGEAR Moderator
Try to port forward
https://kb.netgear.com/24290/How-do-I-add-a-custom-port-forwarding-service-on-my-Nighthawk-router
https://support.microsoft.com/en-us/help/4026770/xbox-open-these-network-ports-for-xbox-one
DarrenM
