    • Ace321's avatar
      Ace321
      Apprentice
      Thank but I do not see SPC tile as per instructions in Orbi app.
      • Ace321's avatar
        Ace321
        Apprentice
        Never mind it finally showed up as a pop up. Thanks
  • <<I previously posted somewhere else and is redirected to post here>>
    I have a RBK753 purchased from COSTOC.
    Now it runs on V4.6.3.7_2.0.49 on all 3 units (One RBR750, two RBS750). I could not find SPC in either the Orbi mobile app, or the web UI.
    I did a few things
    • factory reset on the entire kit last night,
    • uninstall/reinstall Orbi app on my android phone,
    • clean up the storage/cache on my android phone,
    • install Orbi app on my wife's iPhone.
    It does not offer me with SPC.
    Anyone know what else trick I should try, or help me debug this issue. Your input is appreciated.
    Thanks!
    • FURRYe38's avatar
      You not seeing anything in the Orbi app?
      https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
      I did a few things
      Thanks!
      • LiquidP's avatar
        LiquidP
        Tutor
        That is correct. It does not offer SPC tile on the orbi app.
    • FURRYe38's avatar
      Any progress on this?
      I did a few things
      Thanks!
      • agaurav's avatar
        agaurav
        I have the same problem. I have an Android phone with the Orbi app version 2.11.0.1661. The hardware Orbi RBR850 firmware version is v3.2.18.1. I do not see the Smart Parent Control tile.
        What else can I try?
