dawnhamilton
May 31, 2016Aspirant
7 Routers on our network acting as Access points but when I add the 8th router the network crashes
I have a comcast modem giiving out DHCP, the 7 routers are set up as access points not giving out DHCP obviously and it works fine, When I add the 8th router as an access point the network fails, som...
JohnRo
May 31, 2016NETGEAR Employee Retired
Hello dawnhamilton,
Welcome to the community!
What are the model number(s) of the routers that your are using? Apparently they are designed as routers so I would think that they are quite different in handling the traffic. A controller can handle up to 16 APs. This could be something else, how much IP can your modem/router give and how many users do you have simultaneously?
Thanks,
dawnhamilton
1 R6250 and the rest are all netgear 750's
We have about 120 online users at any one time. Its a regular comcast modem but Im going to upgrade to a surfboard 6121 in a month or so
- frankeezipperJun 05, 2016Aspirant
You have to take out the modem/router out of router mode and turn it into bridge mode. Therefore one will support the other and the firewall will be a lot more secure
