dawnhamilton
May 31, 2016Aspirant
7 Routers on our network acting as Access points but when I add the 8th router the network crashes
I have a comcast modem giiving out DHCP, the 7 routers are set up as access points not giving out DHCP obviously and it works fine, When I add the 8th router as an access point the network fails, som...
frankeezipper
Jun 05, 2016Aspirant
Can you pleasse tell me if this is a commercial account that you are asking about. If you are using this in home how many square feet are you trying to cover?
