Matthew617's avatar
Matthew617
8-stream AX WiFi Gateway (CAX80)
I have 1 gig service from Spectrum and the ethernet connections tops out at 450-600 while my 5g wireless is 1100.  Spectrum came and checked the line and all was good.
I can't see any  obvious setting issues- any suggestions?  I used both the Olka speedtest app and the Nighthawk one...
Any suggestions or help would be greatly appreciated.
  • FURRYe38's avatar
    What ethernet device are you speed testing with?
    What CAT# cable are you using? CAT6 is recommended.
    Is ethernet device connected to the Multi Gig port or a 1Gb port?
    Is Armor, or traffic meter enabled?
    • Matthew617's avatar
      Matthew617
      HP Laptop
      Cat8
      I've tried all the ports, port aggregation is not enabled.
      Armor Not Active
      Traffic Meter
      Cancel Apply
      Internet Traffic Meter
      Enable Traffic Meter
      Traffic volume control by
                    No limit              Download only              Both directions
      Monthly limit
      Firmware VersionV2.1.3.7
      Cable Firmware VersionV1.02.08
      • FURRYe38's avatar
        So I Traffic meter enabled, hard to tell.
        Try a different ethernet device?
        Has a factory reset and setup from scratch with out Armor or Traffic Meter being enabled and see?
