FH12345
Apr 08, 2017Aspirant
AC 1600 WIFI CABLE MODEM ROUTER, MODEL #C6250 installation
I'm trying to set up my Internet, I have a AC 1600 wifi cable modem router, model number C6250. I'm currently using centurylink. I've plugged a coaxial cable that's connected to the wall into the rout...
DarrenM
Apr 10, 2017Sr. NETGEAR Moderator
Hello FH12345
If you are not getting a internet connection at all then you will have to contact the ISP again something is not right with the connection. What are the lights doing on the front of the modem?
DarrenM
