EHP61's avatar
EHP61
AC 1750 WIFI not broadcasting
My router just quit broadcasting WiFi, I have reset and restarted multiple times with no luck.  Power, upstream, down stream and internet lights all green. No other lights are on. Pushing and holding wifi on/off swithch does nothing.
My laptop does not have a network port and I can't connect using WiFi. How can I connect to the router without a network cable or Wifi?
    • EHP61's avatar
      EHP61
      The main problem is connecting my laptop to the router. My laptop does not have a network port. USB only.
      • michaelkenward's avatar
        michaelkenward
        You can buy a USB device that creates a wired LAN port.
        As seen on Amazon, its costs around $£€10. There are many more like it.
        Always worth having around.
        Disclaimer: Just another user with time on their hands.
  • plemans's avatar
    AC1750 is a speed, not a model. what actual model do you have?
    did you push and hold the wifi on/off button for at least 2 seconds.
