Magno
Aug 11, 2017Follower
AC 1900 cable modem and AC3200 x6 wifi router
My problem is that I try to connect my wifi router with my modem that I just bought but it is asking me to disable wifi gateway from my existing wifi which is the modem. How can I disable it so that I...
DarrenM
Aug 16, 2017Sr. NETGEAR Moderator
Hello magno
You modem should have a modem only mode or you would have to disable the DHCP server on the modem.
DarrenM
