swimwooly
Dec 15, 2016Aspirant
AC1750 C6300 Blinking internet light - upload & download both work - xfinity
I bought a new cable Modem Router to go with my new xfinity internet service and I can't get it to connect to the internet. All of the lights work with the exception of the internet light which flas...
- Dec 19, 2016Honestly, it sounds like it was an Xfinity issue with activation, not the gateway itself. I'm glad it started working for you. I'm pretty happy with mine so far. Just wish it had more features I could change. đ
Griffscavern
Dec 16, 2016Aspirant
Hi swimwooly,
I just bought the same router and got Xfinity internet last Friday. All I had to do was connect it straight to the wall outlet, fire it up the activate through xfinity's activation process. It connected seamlessly. I've had an issue with a T3 ranging response timeout but never lost internet connection (only 1 of the upload channels, of 4, locked.) I just did a factory reset using the pin hole on the router and the issue went away. Other than that I've had no issues. Have you tried doing a factory reset on the modem and letting it reboot to see if that solves your issue?
