oldman2's avatar
oldman2
AC1750 C6300 bridge mode
Hello, How can I access the control panel of an AC1750 C6300 when it is in bridge mode from a browser thru a router N600?  http://192.168.0.1 doesn't fail but doesn't bring up the screen and  http://routerlogin.net brings up my N600 login.  I am replacing an N300 C3000 which did this using 192.168.100.1.  TNX
  • > [...] I am replacing an N300 C3000 which did this using 192.168.100.1.
       Did you try "192.168.100.1" (possibly after disconnecting the router,
    and connecting a computer directly to the C3000)?
    > [...] a router N600 [...]
       "N600" is a speed, not a model number.  Look at the product label.
    • oldman2's avatar
      oldman2
      Sorry, try WNDR3400 as the model number.
      Anyway, I am trying to transfer all the router setup from the WNDR3400 to the AC1750 C6300. Access list is stumping me, I'm used to be able to transfer devices from the Attached Devices list to the Access Control list by clicking.  TNX
      How can I attach a screen capture here?
      • FURRYe38's avatar
        You'll need to manually input any configurations into the router your going to use as your router.
        Are you using the C6300 as your main host router?
  • I need to re-state my problem more precisely. I have the AC1750 C6300 in Bridge mode, how do I get it back into the default Gateway mode given that ip 192.168.0.1 does not connect?
    TNX
    • antinode's avatar
      antinode
      Guru
      > [...] how do I get it back into the default Gateway mode given that ip
         Visit http://netgear.com/support , put in your model number, and look
      for Documentation.  Get the User Manual.  Read.  Look for "reset".
         Still wondering.
      • oldman2's avatar
        oldman2
        Thanks for responding,  I have connected the AC1750 C6300 (while in bridge mode) directly to the computer. It does not respond to either 192.168.0.1 or 192.168.100.1;  I'm hoping somebody knows the correct address.  I hate to think I must use the previous suggestion from another user.
        Reset, yes, I have downloaded the user manual and I know how to do (and have done) a full reset and it does work.  Unfortunately all the configuration work I have done gets blown away also.  Its a very painful way to just change the mode. And no, I can't get back into the AC1750 C6300 to back up the configuration before doing the reset. Sorry, not wanting to be a jerk but this is frustrating.
        TNX
