Scott5485
Jun 08, 2023Aspirant
AC1750 WiFi Cable Modem Router (C6300v2)
I have Spectrun. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
- KitsapMaster
Scott5485 wrote:I have Spectrun. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
What device are you using to check your throughput? Laptop, desktop, phone, etc.?
How is it connected to your C6300v2, via Wi-Fi or via Ethernet?
What application are you using to check your throughput? Recommend the stand alone installable application from Ookla, it is available free in the play store for all devices.
Normally your device would be discussed in the cable modem community here:
https://community.netgear.com/t5/Cable-Modems-Gateways/bd-p/home-cable-modems-routers
A moderator may move this discussion.
- Scott5485Aspirant
I'm using a desktop to check. It is hardwired to modem/router. I used spectrum speed check to verify speed.
- Scott5485Aspirant
I have Spectrum. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
