mmfallon's avatar
mmfallon
AC1900 - Model C7000v2 Router will give laptops internet access but not mobile devices
yesterday, we had a power outage. When power came back on, laptops reconnected to the router. The phones - an iPhone and an Android - can't connect to the internet. I disconnected ("forget") on the android. When I reconnected, after reconnnecting, it won't connect to the internet. If I wait, it says "tap here to connect" and brings me to routerlogin.com - the admin account settings page.
  • plemans's avatar
    have you tried simply factory resetting the router and reinstalling it?
      • plemans's avatar
        Have you tried changing the wifi ssid and password to something new?
  • FURRYe38's avatar
    For iPhones did you turn OFF "WiFI Private Address" feature on the phone?
    • mmfallon's avatar
      mmfallon
      Thank you for the input. I ended up replacing the router as other apps stopped working.
      • FURRYe38's avatar
        Be aware that Apples new WiFi Privacy Address feature is causing some problems. Something you can disable while at home. If you travel, enable it then.
        Good Luck.
