anakin827's avatar
anakin827
AC1900 C7100V Static Routes
I have the AC1900 Nighthawk Modem/Router and trying to understand if I can set up a static route in this particular model?
  • Hi anakin827,
    Static Routes not supported for C7100V.
    • anakin827's avatar
      anakin827
      Well that stinks.  Any other ways to possibly do it since this device cannot support?
      • antinode's avatar
        antinode
        Guru
        > Well that stinks. [...]
           I agree.
        > [...] Any other ways to possibly do it since this device cannot
        > support?
           Use another device?  Use the C7100V as a modem-only, and get a
        competent router to use as a router?
           Why do you need static routes?  (I use them on my D7000 to get to
        odd-ball devices/subnets like a SIMH-emulated VAX, or an old Raspberry
        Pi Zero which has only USB networking, or the second Ethernet port on a
        Mac Pro, or the like.)
