tdiddy1226's avatar
tdiddy1226
adding a 5GHz wifi router
can a 5GHz wifi router be added onto a c3000 through the network connection?
  • It supports DHCP. If you have a spare port on the C3000, you should be good to go..
    EDIT: Your new router would need to be configured in Access Point mode, prior to adding to the C3000.
    • tdiddy1226's avatar
      tdiddy1226
      I just got the c3000 and also just got comcast. I cut the cord with cable and am just streaming now. I'm getting above the rated speed on wire but the wifi is dropping with 2 wireless devices streaming. They don't lag much but I do see a delay in loading. I think I'm just going to return the modem and go for the c3700 since it boasts simultaneous dual band 2.4 and 5.0.
      • HiThere22's avatar
        HiThere22
        Star
        The c3700 is known to have issues with Comcast due to the firmware they push,  I would invest in a seperate modem and router seem to have more flexability with device like that
