MJBoater
Nov 14, 2017Aspirant
Best Router for CM1000
So I just purchased the CM1000. I am using Xfinity (Comcast) for ISP. I have the 300 meg down package now (just switched from 75 neg yesterday which caused me to upgrade to the CM1000 from a Arris ...
vitocorleone
Nov 22, 2017Tutor
Router or WiFi access point or router with wifi? If you're looking for one of the best wired routers and will add one of the best wifi systems - check out the Ubiquiti products. If you're looking for a combined router+wifi, I'd stick with Asus and get the AC86U.
- MJBoaterNov 22, 2017Aspirant
i went for 86U
