husam
Sep 06, 2015Aspirant
blocking app access on N450 CG3000Dv2
hi, from the admin console on my N450 (using with Time Warner Cable) i can enter domain or keyword blocks, and they work fine on my windows PCs. but anything running an app (Android phones and tabl...
DarrenM
Sep 08, 2015Sr. NETGEAR Moderator
Hello husam
I don't believe there is a way to block apps from working threw the router but I do see there are apps on the Apple and android markets that are parental controls that can be installed and some let you set them from your own device. I do not have any recommendations on which one to use never tried them before but you may want to look into it.
DarrenM
