benjedi420vt's avatar
benjedi420vt
Broken WAN port, can I use LAN port R6900
Hi,
To hopefully make this easier to navigate I've put my questions up at the top but to get the context please read below
Q1: If the WAN/Internet/yellow port is dead, is there anyway to "remap" one of the LAN ports on this router to be used as the WAN port instead since it appears these ports are working fine?
Q2: It appears the WAN port is dead...any ideas how to fix it or is it probably unfixable (by me)?
Yesterday was using the weather channel app on my phone thru WiFi looking at the radar when all of a sudden the internet stopped. Seems a bit mysterious to me but when looking at the router the normally illuminated internet symbol (little round thig that looks like a planet maybe) was dark. Also noticed that the LAN symbol on the cable modem (Xfinity ISP) was out. To check the modem, I unplugged the cable from the WAN port on the router, plugged into a LAN port on my laptop (remember no WiFi) and the laptop connected to internet right away and worked fine.
I factory resetted the modem and same issue. I then connected (looping) the same ethernet cable from the WAN port to a LAN port on the router and still the WAN port symbol stayed off. The router (LAN) still seems to be working fine as I can connect thru the WiFi and access devices on my home network. Lastly, using my PC connected to the router thru a LAN port I logged intot the router, went to "internet" and clicked on statistics or some other button and the WAN port was "Link down" or "down link" and all the other data fields were blank (the LAN port used by my PC had active data onbviously as I was using it).
Thanks for any help given!
  • plemans's avatar
    If you go to your routers ip address + /debug.htm  there used to be a map wan port to lan port 1
    so if your address is 192.168.1.1  you'd go to:
    192.168.1.1/debug.htm
    • benjedi420vt's avatar
      benjedi420vt
      Hi. Thanks for this response. So I went to the debug page and there was a option to check called
      WAN mirror to LAN port 1
      Is that what you were referring to?
      Anyway, I checked it, unplugged my home network LAN cable from LAN port 1 and put it into LAN port 2. Then I unplugged my cable from the WAN port and pluged it into the LAN port 1. Then I rebooted the router.
      The home netowrk seems to be working but unfortunately the internet is still out.
      Ben
      • plemans's avatar
        What modem is it?
        Did you power off the modem and the router for 2 minutes,
        then power the modem on, give it 2 minutes, and power the router on?
