nandun5's avatar
nandun5
Follower
Dec 04, 2015
C3000 - Cannot access Genie after disabling Router Mode
I changed Router Mode setting to "No" on my C3000 because i wanted to use a separate wifi router (R7000)
As expected the wifi network that was on my C3000 disappeared.
Now my question is, How to I change the Router Mode setting to "Yes" again?
I cannot access the C3000 management console (genie) on 192.168.0.1 like I used to.
routerlogin.net takes me to the console of the R7000.
It doesn't work even when I plug in the cable. How do I get it back?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello nandun5
    You can do a factory reset it should fix the issue. if not have you gone directly to the C3000 with a ethernet cable and try to connect.
    DarrenM
