sammckira
Sep 06, 2016Follower
C3000 ping issues
Recently, about every 20 minutes to an hour my ping will jump from around 30 to 600. If I restart the router/modem the ping will go back to normal, but not until then, so I know it is a problem with ...
DarrenM
Sep 08, 2016Sr. NETGEAR Moderator
Hello sammckira
I would check all your cable lines and ethernet cords make sure those are good maybe swap them out. Also if you have a cable splitter connected to the modem try removing that see if ping issue stops happening.
DarrenM
