stomptoblock's avatar
stomptoblock
C3000 to C3700 Wireless AP HELP!!!
Hi, I have two gateway routers, a C3700 as my main. i have crapy wifi in some parts of my house and i have another C3000. I would like to turn the C3000 into a Wireless AP but when i go to the Wireless AP page on the 192.168.0.1 thing... i can't click or join any network!!!
please help!
            dom
  • AP (Access Point) mode requires an Ethernet connection to the main router.  You may be thinking of a range extender, which is different.
  • But it says in the settings of the router that you can wireless connect it to anothet router so that the one connecting to another router can be used as a wireless ap
    • TheEther's avatar
      TheEther
      Guru
      It would be unusual for the C3000 to have this capability.  Netgear usually does not provide it in their routers.
      stomptoblock wrote:
      Also the router doesn't have a Ethernet in port on it...
      Are you talking about the C3700?  It has two Ethernet ports.
      stomptoblock wrote:
      Can a range extender be used to wireless connect to my main router if so, can i use my current setup for this?
      Yes you can use a range extender to wirelessly connect to your main router.  It won't, however, be as fast as a wired Access Point.
  • Can a range extender be used to wireless connect to my main router if so, can i use my current setup for this?
    • TheEther's avatar
      TheEther
      Guru
      If you want to set up the C3000 as a wired Access Point, then you can use either Ethernet port.
    • TheEther's avatar
      TheEther
      Guru
      Sorry if my prior answer wasn't clear.  No, you cannot use it as a wireless access point.
