cobbjtn1
Jan 22, 2016Aspirant
C3000 wifi modem and 2 additional routers
What would be the best way to connect 2 additional routers to my WiFi modem, essentially having 3 networks? The WiFi modem network for devices such as my thermostat. The 2nd router network for my wife...
DarrenM
Jan 22, 2016Sr. NETGEAR Moderator
Hello cobbjtn1
The best way to do it is see if the other 2 routers you are using have a access point mode on them that will stop routing conflicts from happening but if they do not have that modem you will want to look for DHCP in the settings of those routers and disable them.
DarrenM
