cobbjtn1
Jan 22, 2016Aspirant
C3000 wifi modem and 2 additional routers
What would be the best way to connect 2 additional routers to my WiFi modem, essentially having 3 networks? The WiFi modem network for devices such as my thermostat. The 2nd router network for my wife...
cobbjtn1
Should I connect both routers LAN to WAN one to each of the 2 ports on the WiFi modem? Leave DHCP on for the WiFi modem and turn DHCP off for both routers? My WiFi modem is 192.168.0.1. A router is 192.168.1.1 and B router auto changed to 10.0.0.1.
DarrenM
Jan 22, 2016Sr. NETGEAR Moderator
Correct the C3000 should have the DHCP on while the other 2 have it off and you want to connect from the LAN ports of the C3000 to the WAN ports of the other 2 routers.
DarrenM
