scm53
Jun 25, 2016Aspirant
c3700-100NAS
I got a Samsung Smartthings hub v2 to replace my v1 hub, thinking it would be a 1 for 1 swap. Boy was I wrong. Plugged it in, continuous blue light. Tried calling ST support about it. Got told it mus...
DarrenM
Jul 01, 2016Sr. NETGEAR Moderator
Hello scm53
In each line you would put the port in the start box and the ending so 11111 in the start and ending then you will select UDP and then you want to select the 192.168.0.x address for the samsung device and click apply then repeat this process for every port you need to open.
DarrenM
scm53
Jul 22, 2016Aspirant
Darren: Wound up have to plug the Samsung Smartthings hub into one of two ports on my cable modem/router. It would not function if it were attached to a powered switch instead. Which has not caused another problem with no wired device being seen.
