slowifii
Jun 29, 2016Aspirant
C3700, AC or not??
Hi there, just curious does the c3700 modem router support 802.11 AC at 5ghz? I've seen pictures of the box and it only shows A/N at 5ghz, the downloadable tech specs show A/N as well for 5ghz, but the c3700 webpage shows it supports AC at 5ghz. Some conflicting info here, so is AC supported or not?? Thanks for the info!!
Hello slowifii
It is only a/n here is a link to the specs
http://www.downloads.netgear.com/files/GDC/datasheet/en/C3700.pdf
DarrenM
- slowifiiAspirant
- DarrenMSr. NETGEAR Moderator
Hello slowifii
DarrenM
